查看: 359|回复: 0
PIC18F87J72评估板
  • 签到天数: 361 天
    发表于 2013-12-24 17:10:26 | 显示全部楼层 |阅读模式
    PIC18F87J72评估板是基于pic18f87j72装置的应用提供了平台以此用来开发和评估。Summary Description:The PIC18F87J72 Evaluation Board provides a platform for developing and evaluating applications which are based on the PIC18F87J72 device. These applications can range from accurate measurement of low signals like an output signal of a load cell to processing of information for metering and other metrology applications like Energy meter, Flowmeter, Heatmeter and so on. The device is capable of interfacing to a large variety of voltage and current sensors, including shunts, Current Transformers (CT), Rogowski coils and Hall Effect sensors.This Kit Contains:● PIC18F87J72 Evaluation Board● Preprogrammed PIC18F87J72 Microcontroller on board● MCP2200 device on board● Mini Universal Serial Bus (USB) Connecting CableFeatures:● Robust hardware design for low noise evaluation of the high performance A/D Converters (ADC)● Seven-Segment LCD Display● Real Time Clock and Calendar function● Capacitive Touch keys● PICtail™ connectors for PIC18 daughter boards● Easy configuration of the Dual-Channel Delta-Sigma ADC● ADC bit width of 16- or 24-bit● Internal PGA gain of 1, 2, 4, 8, 16, or 32● Over Sampling Ratio (OSR) of 32, 64, 128, or 256● Graphical PC tools for system and ADC performance analysis● Noise histogram● Frequency domain (FFT)● Time domain scope plot● Statistical numerical analysis
    ADM00333 Gerbers .zip
    701.52 KB, 下载次数: 0
    PIC18F87J72 Evaluation Board (ADM00333) BOM .pdf
    28.27 KB, 下载次数: 0
    PIC18F87J72 Evaluation Board (ADM00333) Firmware .zip
    52.08 KB, 下载次数: 0
    PIC18F87J72 Evaluation Board (ADM00333) GUI Software .zip
    1.08 MB, 下载次数: 0
    PIC18F87J72 Evaluation Board (ADM00333) Schematics .pdf
    165.26 KB, 下载次数: 0
    PIC18F87J72 Evaluation Board User's Guide .pdf
    2.54 MB, 下载次数: 0
    GMT+8, 2024-11-26 05:25 , Processed in 0.108934 second(s), 16 queries , MemCache On.
