查看: 228|回复: 0
AC164127-5 演示板
  • 签到天数: 361 天
    发表于 2013-12-24 16:31:41 | 显示全部楼层 |阅读模式
    AC164127-5 演示板主要用于显示器,LCD 控制器。The Graphics LCD Controller PICtail™ Plus SSD1926 Board is a demonstration board for evaluating Microchip Technology’s graphic display solution and graphics library for 16- and 32-bit microcontrollers. It is an expansion board compatible with the Explorer 16 development board (DM240001) or one of the PIC32 Starter Boards (DM320001, DM320003). The controller board has a connection for the display boards, such as the Graphics Display Truly 3.2 240x320 Board (AC164127-4). The features include:Graphics display controller Solomon Systech SSD1926 supporting 4/8 bit STN, 4/8 bit CSTN, 18-bit HR-TFT, and 9/12/18/24 bit TFT interface
    • SD/MMC Card socket, connected to SSD1926 via 4-wire interface
    • 16 Megabit (2Mx8) serial flash memory for additional data storage
    • Display connector for interfacing with different display boards
    • PICtail Plus Interface for connecting to Explorer 16 Development Board
    • PIC32 Starter Kit Connector
    How to Use Widgets in Microchip Graphics Library .pdf
    473.39 KB, 下载次数: 0
    Using a Keyboard with the Microchip Graphics Library .pdf
    150.86 KB, 下载次数: 0
    How to Create Widgets in Microchip Graphics Library .pdf
    208.86 KB, 下载次数: 0
    Developing Graphics Apps using PIC MCUs w/Integrated Graphics Controller .pdf
    580.71 KB, 下载次数: 0
    Graphics LCD Controller PICtail Plus SSD1926 Info Sheet .pdf
    219.91 KB, 下载次数: 0
    GMT+8, 2024-11-26 05:32 , Processed in 0.119676 second(s), 16 queries , MemCache On.
