TA的每日心情 | 奋斗 2014-7-16 09:10 |
签到天数: 361 天 连续签到: 1 天 [LV.8]以坛为家I
DV164139 开发包是低引脚数的USB开发包,它提供了一个简单的,对芯片pic18f14k50和pic18f13k50 20针USB控制器的功能,低成本的方式。The Low Pin Count USB Development Kit provides an easy, low-cost way to evaluate the functionality of Microchips PIC18F14K50 and PIC18F13K50 20-pin USB microcontrollers. The kit also supports the PIC16F145x USB MCUs in 14- and 20-pins. This kit contains the hardware needed to get you started. Software and code examples necessary to bring your next USB design from concept to prototype are downloadable from the product website. This material was created with the USB novice in mind and includes Getting Started with Microchips Low Pin Count USB Solutions, a self-directed course and lab material designed to ease the learning curve associated with adding USB connectivity to embedded systems. This kit contains one fully populated Low Pin Count USB Development Board, one unpopulated spare development board, one PIC18F14K50 Debug Header, and one PICkit 3 In-Circuit Debugger with cable. Note: The PICkit 3 is NOT a production programmer. |
