TA的每日心情 | 奋斗 2014-7-16 09:10 |
签到天数: 361 天 连续签到: 1 天 [LV.8]以坛为家I
TDGL006 演示板主要运用于接口,网络屏蔽。The chipKIT development platform is a 32-bit Arduino solution that enables hobbyists and academics to easily and inexpensively integrate electronics into their projects, even if they do not have an electronic-engineering background. The platform consists of two PIC32-based development boards and open-source software that is compatible with the Arduino programming language and development environment. The chipKIT hardware is compatible with existing 3.3V Arduino shields and applications, and can be developed using a modified version of the Arduino IDE and existing Arduino resources, such as code examples, libraries, references and tutorials. The chipKIT Basic I/O Shield (part # TDGL005) announced today is compatible with the chipKIT Uno32™ and Max32™ boards, and offers users simple push buttons, switches, LEDs, I2C™ EEPROM, I2C temperature sensor, and a 128 x 32 pixel organic LED graphic display. The chipKIT Network Shield (part # TDGL006) enables users to use the chipKIT Max32™ development board to implement 10/100 Ethernet, USB OTG and CAN communications.
- 10/100 Ethernet
- USB Host, Device, OTG
- Dual CAN transceivers
- Dual I2C connectors
- 245kbit EEPROM
- 32.768 KHz oscillator for RTCC
Note: Requires chipKIT Max32 (TDGL003) |
