TA的每日心情 | 奋斗 2014-7-16 09:10 |
签到天数: 361 天 连续签到: 1 天 [LV.8]以坛为家I
AC164130-2 接口板主要用于接口,CAN,ECAN LIN,它的主要属性是2 CAN 和 2 LIN 收发器,4 个通过插口连接的 IC。The CAN/LIN PICtail (Plus) Daughter Board is used with the Explorer 16 Development Board or PIC18 Explorer Board to facilitate rapid implementation and evaluation of applications that use Controller Area Network (CAN) and Local Interconnect Network (LIN) interfaces. Features include two ECAN nodes with MCP2551 transceivers, two LIN nodes with MCP2021-330 transceivers, LIN Master or Slave selectable option, and external power supply input. the PICtail interface is used for connection to the PIC18 Explorer for PIC18 8-bit microcontrollers. The PICtail Plus interface is used for connection to the Explorer 16 Board for PIC24 16-bit microcontrollers and dsPIC33F Digital Signal Controllers.Features:
- Connector to Explorer 16 Development Board and PIC18 Explorer Board
- Two CAN communication channels interfacing to ECAN module
- Two LIN communication channels interfacing to UART module
