查看: 238|回复: 0
MCP43X评估板
  • 签到天数: 361 天
    发表于 2013-12-27 14:08:46 | 显示全部楼层 |阅读模式
    MCP43X评估板允许系统设计者快速评估微芯片技术,在20引脚封装如型TSSOP - 20/16/14/8和SSOP - 20下的设备进行操作。Summary Description:The 20-Pin TSSOP and SSOP Evaluation Board allows the system designer to quickly evaluate the operation of Microchip Technology’s devices in any of the following 20-pin packages: TSSOP-20/16/14/8 and SSOP-20.The board has a 6-pin header (PICkit Serial, ICSP, etc.) that can be easily jumpered to the device’s desired pins to communicate with the device (using PICkit Serial) or in the case of PIC microcontrollers or EEPROM, programmed (using ICSP).The board also has footprints for a crystal circuit (for PIC microcontrollers) This board is generic so that any device, of the appropriate footprint, may be installed.As well as the device, other desired passive components (resistors and capacitors) and connection posts may be installed. This allows the board to evaluate a minimum configuration for the device. Also, this allows the device to be easily jumpered into an existing system.Features:Connection terminals may be either through-hole or surface-mountTwo package type footprints supported - TSSOP and SSOPFootprints for optional passive components on each pinFootprints for PIC microcontroller crystal circuitPICkit Serial Analyzer / PICkit 2 Programming (ICSP) HeaderSilk-screen area to write specifics of implemented circuit
    20-Pin TSSOP and SSOP Evaluation Board Gerbers .zip
    185.06 KB, 下载次数: 0
    Quick Guide to Microchip Development Tools .pdf
    7.21 MB, 下载次数: 0
    20-Pin TSSOP and SSOP Evaluation Board User's Guide .pdf
    735.05 KB, 下载次数: 0
    GMT+8, 2025-1-16 11:04 , Processed in 0.122734 second(s), 16 queries , MemCache On.
