Allegro的ACS758系列电流传感器IC可为交流或直流电流感测提供经济型和精确的解决方案。典型的应用包括电动机控制,负载检测和管理,电源和直流 - 直流转换器控制,逆变器控制和过电流故障检测。该装置由一个精确,低偏移的线性霍尔电路与位于模具附近的一个铜制的电流路径组成。流过该导通通路施加电流产生一个磁场,该磁场的霍尔集成电路转换为成比例的电压。设备的精度的优化是通过磁信号霍尔传感器的靠近。FEATURES AND BENEFITS
- Industry-leading noise performance through proprietary amplifier and filter design techniques
- Integrated shield greatly reduces capacitive coupling from current conductor to die due to high dV/dt signals, and prevents offset drift in high-side, high voltage applications
- Total output error improvement through gain and offset trim over temperature
- Small package size, with easy mounting capability
- Monolithic Hall IC for high reliability
- Ultra-low power loss: 100 μΩ internal conductor resistance
- Galvanic isolation allows use in economical, high-side current sensing in high voltage systems
- AEC Q-100 qualified
