查看: 410|回复: 0
打印 上一主题 下一主题
ATSAM4S-XSTK开发套件
  • 签到天数: 11 天
    跳转到指定楼层
    楼主
    发表于 2013-9-10 13:53:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    ATSAM4S-XSTK开发套件主要包括SAM4S评估板和扩展PCB板(输入输出扩展板、OLED显示扩展板和原型扩展板)以及2根USB连接线。主要用于微处理器ATSAM4S系列入门学习。The Atmel® SAM4S Xplained Pro starter kit is ideal for evaluating and prototyping with the SAM4S Cortex™-M4 processor-based microcontroller. The SAM4S Xplained Pro board is available as an Evaluation Kit or Starter Kit. You can also purchase extension boards individually.Key Features
    • Atmel SAM4SD32 microcontroller
    • One reset button
    • One user pushbutton (wake-up, bootloader entry or general purpose)
    • One yellow user LED
    • USB interface, end-point
    • 2Gb NAND Flash
    • 32.768kHz crystal
    • 12MHz crystal
    • SD card socket
    • 3 Xplained Pro extension headers
    • One display header
    • One PIOD connector with all PIO signals
    • One SPARE signal connector
    • Embedded debugger
      • Auto-ID for board identification in Atmel Studio 6.1
      • One yellow status LED
      • One green board power LED
      • Symbolic debug of complex data types including scope information
      • Programming
      • Data Gateway Interface: SPI, TWI and 4 GPIOs
      • Virtual COM port (CDC)
    • USB powered
    • Supported with application examples in Atmel Software Framework
    举报
    站长推荐上一条 3/5 下一条
    【预约|参会享"豪"礼】2025慕尼黑上海设备展
    查看 »
    GMT+8, 2025-4-30 04:38 , Processed in 0.109630 second(s), 17 queries , MemCache On.
