查看: 307|回复: 0
ATmega256RFR2 Xplained Pro入门套件
  • 签到天数: 11 天
    发表于 2013-9-4 14:49:35 | 显示全部楼层 |阅读模式
    ATmega256RFR2 Xplained Pro入门套件主要包括ATmega256RFR2评估板和扩展PCB板(输入输出扩展板、OLED显示扩展板和原型扩展板)以及2根USB连接线。主要用于微处理器ATmega256RFR2入门学习。The ATmega256RFR2 Xplained Pro starter kit is ideal for evaluation and prototyping with the ATmega256RFR2 microcontroller. The ATmega256RFR2 Xplained Pro board is available as an evaluation kit or starter kit. Extension boards can also be individually purchased.The ATmega256RFR2-XSTK starter kit includes the Atmel I/O1 Xplained Pro, OLED1 Xplained Pro, and PROTO1 Xplained Pro extension boards.If all you need is just the MCU evaluation board, the ATmega256RFR2-XPRO evaluation kit is available and does not include extension boards.This kit will be available at the end of April. To be notified when the kit is available, you can register at the Atmel Store by clicking on the "Buy Tool" button.
    Key Features
    • ATmega256RFR2 microcontroller
    • One mechanical reset button
    • One mechanical user pushbutton (wake-up, bootloader entry or general purpose)
    • One yellow user LED
    • 32.768kHz crystal
    • 16MHz crystal
    • 5 Xplained Pro extension headers (2 headers are duplicates)
    • Antenna diversity: Ceramic RF antenna and SMA connector for external antenna
    • Temperature sensor
    • Embedded debugger
      • Auto-ID for board identification in Atmel Studio 6.1
      • One yellow status LED
      • One green board power LED
      • Symbolic debug of complex data types including scope information
      • Programming
      • Data Gateway Interface: SPI, TWI, 4 GPIOs
      • Virtual COM port (CDC)
    • USB powered
    • Supported with application examples in Atmel Software Framework
    ATmega256RFR2 Xplained Pro评估套件用户指南.pdf
    833.92 KB, 下载次数: 0
    GMT+8, 2024-11-26 06:32 , Processed in 0.138808 second(s), 16 queries , MemCache On.
