TA的每日心情 | 开心 2013-9-2 09:06 |
签到天数: 11 天 连续签到: 1 天 [LV.3]偶尔看看II
ATSAM4L-XSTK评估套件主要包括SAM4L评估板和扩展PCB板(输入输出扩展板、LCD液晶扩展板、OLED显示扩展板和原型扩展板)以及2根USB连接线。主要用于微处理器ATSAM4L系列入门学习。The SAM4L Xplained Pro starter kit is ideal for evaluation and prototyping with the SAM4L Cortex™-M4 processor-based microcontroller. The SAM4L Xplained Pro board is available as an evaluation kit or starter kit. Extension boards can also be individually purchased.The ATSAM4L-XSTK starter kit includes the Atmel I/O1 Xplained Pro, OLED1 Xplained Pro, PROTO1 Xplained Pro, and SLCD1 Xplained Pro extension boards.If the MCU evaluation board is all you need, the ATSAM4L-XPRO evaluation kit is available and does not include extension boards.
Key Features
- SAM4LC4 microcontroller
- One mechanical reset button
- One mechanical user pushbutton (wake-up, bootloader entry or general purpose)
- One QTouch button
- One yellow user LED
- USB interface, host and device function (shared physical interface)
- 32.768kHz crystal
- 12MHz crystal
- 4 Xplained Pro extension headers
- One custom extension header for segment LCD displays
- LDO/Buck regulator mode selection
- LCD cluster power configuration option
- Embedded debugger
- Auto-ID for board identification in Atmel Studio 6.1
- One yellow status LED
- One green board power LED
- Symbolic debug of complex data types including scope information
- Programming
- Data Gateway Interface: USART, TWI, 4 GPIOs
- Virtual COM port (CDC)
- USB powered
- Supported with application examples in Atmel Software Framework
