查看: 305|回复: 0
DE0(3C16) CYCLONE FPGA开发套件
发表于 2013-7-31 17:03:37 | 显示全部楼层 |阅读模式
DE0(3C16) CYCLONE FPGA开发套件中的DE0板需在Windows系统上安装运行。The DE0 board has many features that allow the user to implement a wide range of designed circuits,from simple circuits to carious multimedia projects.The DE0 board comes with a Control Panel facility that allows users to access various components on the board from a host computer. The host computer communicates with the board through an USB connection. The facility can be used to verify the functionality of components on the board orbe used as a debug tool while developing RTL code.产品套件
  • The DE0 board
  • USB Cable for FPGA programming and control
  • DE0 System CD containing :
        — Altera’s Quartus® II Web Edition and the Nios® II Embedded Design Suit Evaluation Edition software        — the DE0 documentation and supporting materials, including the User Manual, the Control Panel utility, reference designs and demonstrations,device datasheets,tutorials, and a set of laboratory exercises
  • Clear plastic cover for the board
  • 7.5 DC wall-mount power supply
产品图片
EP4CGX15BF14 FPGA入门套件用户手册.pdf
987.71 KB, 下载次数: 0
GMT+8, 2024-11-26 07:37 , Processed in 0.121532 second(s), 18 queries , MemCache On.
