查看: 198|回复: 0
CYCLONE II FPGA开发套件
发表于 2013-7-31 10:50:40 | 显示全部楼层 |阅读模式
EP2C20F484 FPGA开发套件包括Altera Cyclone II 2C20 FPGA,且预设置于一个硬件参考设计,存储在闪存中。硬件设计人员可以使用该开发板作为复杂嵌入式系统的样板。该开发工具包为用户提供了一个集成控制环境,它包括C++软件控制器,一个USB指令控制器,多端口SRAM/ SDRAM/闪存控制器和Verilog代码指定的演示电路用户。这些特征使得用户可以直接执行和进行测试设计,而无需执行复杂的应用程序界面(API),主机控制软件,或SRAM/ SDRAM /闪存控制器。The Cyclone II FPGA Starter Development Kit features:
  • Cyclone II Starter Development Board
  • Cyclone II EP2C20F484C7N device
  • Configuration
    • USB-BlasterTM download cable (embedded)
    • EPCS4 serial configuration device
  • Memory
    • 8-Mbyte SDRAM
    • 512-Kb SRAM
    • 1- to 4-Mbyte flash
  • Clocking
    • SMA connector (external clock input)
  • Audio
    • 24-bit coder/decoder (CODEC)
  • Switches and indicators
    • Ten switch and four push buttons
    • Four, 7-segment displays
    • Ten red and eight green LEDs
  • Connectors
    • VGA, RS-232, and PS/2 ports
    • Two 40-pin expansion ports
    • SD/MMC socket
  • Cables/power
    • USB cable
    • External power supply (optional, but recommended when using kit with additional accessory daughtercards)
  • Cyclone II FPGA Starter Development Kit CD-ROM
    • Reference designs & demo's targeted for the Cyclone II FPGA Starter development board
    • User manual
    • Reference guide
  • Quartus II Web Edition CD-ROM
  • Nios II Web Edition CD-ROM
DK-CYCII-2C20N用户手册.pdf
3.82 MB, 下载次数: 0
GMT+8, 2024-11-26 07:42 , Processed in 0.116593 second(s), 18 queries , MemCache On.
