W5300 ARM评估板是由基板和WZ830MJ模块组成的。In the base board, ARM920T based Samsung S3C2410A-200MHz processor is built in, and W5300, the hardware TCP/IP chip is used.By using serial port of base board and Ethernet port of WIZ830MJ, the communication environment can be easily set up. You can also test external devices having USB interface through USB Host and Device port.W5300E01-ARM operates on Linux OS. By installing 64MB SDRAM, various applications can operate without any problem.Samsung S3C2410A processor supports NAND Flash Booting. By installing 64MB NAND Flash memory, enough space is provided for bootloader, OS and user application.By using extension connector (40pin * 3, total 120pin), the easy extension is supported for the functions that the base board does not support. |
