查看: 286|回复: 0
W5200 以太网开发工具
发表于 2013-7-31 10:11:59 | 显示全部楼层 |阅读模式
W5200 以太网开发工具W5200E01-M3评估板,可用于iEthernet W5200的测试和原型设计的开发。W5200E01-M3 is composed of a STM32F103C8 based on ARM Cortex M3 CPU core, a W5200 which acts as Hardwired TCP/IP embedded Ethernet controller, and a FT232R which acts as USB-to-UART interface IC. W5200 has been proven in various fields to work as a fully hardwired TCP/IP implemented chip that processes various protocols such as TCP, UDP, IPv4, ICMP, ARP, IGMP, PPPoE, and etc. Cortex-M3 can be used to test W5200’s performance, and the surrounding peripherals can be used to implement various Ethernet Applications. The USB-to-UART interface IC in W5200E01-M3 can be used for UART communication. And the extension pin header (total of 40 pins) allows the user for easy connection and testing. W5200E01-M3 can provide simple example codes based on ANSI C to implement various internet application programs based on W5200. W5200 can be used as a small embedded deice in Power down mode to save power consumption.产品特性
  • W5200 Hardwired TCP/IPcore.
  • Cortex-M3.
  • RJ-45 which is integrated transformer.
  • USB-to-UART interface IC.
  • 40 pin expanded header.
  • 2 user LEDs, 2 Serial TX/RX LEDs ,1 POWER Indicate LED
  • Mode S/W, Reset S/W
  • Power source : USB BUS power (500mA), External VIN (5V)
产品图片
W5200E01_M3用户手册.pdf
3.24 MB, 下载次数: 0
GMT+8, 2024-11-26 07:41 , Processed in 0.123305 second(s), 18 queries , MemCache On.
