LPCXpresso是由Artists、Code Red和NXP联合开发的一款低成本开发工具。Designed for simplicity and ease of use, the LPCXpresso provides software engineers a quick and easy way to develop their applications from initial evaluation to final production. The toolchain supports ARM-based LPC microcontrollers and includes a free Eclipse-based IDE and a low-cost target board combined with a JTAG debugger. There is also a Prototype board and a Base board that let engineers explore the features of the Cortex-M0 LPC11xx/12xx and the Cortex-M3 LPC1343 and LPC1769 microcontrollers on the LPCXpresso target boards. The Prototype board and Base board can also be used together with mbed.产品特性Common features
- Socket for LPCXpresso and mbed module
- 50 pin expansion dual row pin list connector (male, 100mil pitch) for simple connection external designs and to a logic analyzer
- 50 pin expansion dual row header connector (female, 100mil pitch) for simple connection to breadboard
- Battery powering (small coin battery)
- USB interface
- Reset pushbutton
Digital IO
- RGB-LED (can be PWM controlled)
- 5-key joystick switch
- 2 pushbuttons, one for activating bootloader
- Rotary switch with quadrature encoding (timer capture)
- Temperature sensor with PWM output (timer capture)
Analog IO
- Trimming potentiometer input (analog input)
- PWM to analog LP-filtering (PWM output and analog input)
- Speaker output (PWM output)
- Oscilloscope probe inout stage
Serial bus - SPI
- Shift register driving 7-segment LED
- SD/MMC memory card interface
- Dataflash SPI-NOR flash
Serial bus - I2C
- PCA9532 port expander connected to 16 LEDs
- 8kbit E2PROM
- MMA7455L accelerometer with I2C interface
- Light sensor
Serial bus - I2C/SPI shared
- SC16IS752 - I2C/SPI to 2xUART bridge; connected to RS232 full-modem interface and one expansion UART
- 96x64 pixel white OLED (alternative I2C/SPI interface)
Serial bus - UART
- USB-to-serial bridge, with automatic ISP activation
- RS422/485 interface
- Interface socket for XBee RF-module
Specific LPC1768 (incl mbed) support
- CAN bus interface (can be simulated with LPCXpresso LPC1114/LPC1343)
- Ethernet RJ45 connector with integrated magnetic
Dimensions 150 x 180 mmPower Powered via USB (+5V)产品图片 |
