Embedded Artists的LPC1788 MCU开发工具包记忆NXP的高性能ARM Cortex-M3 LPC1788单片机。The Developer's Kit, which includes the LPC1788 OEM Board and the OEM Base Board hardware design, lets the user get up-and-running quickly with the LPC1788 MCU. The LPC1788 OEM Board, also available separately, is equipped with the Cortex-M3 based LPC1788 microcontroller, suitable for a wide range of applications that require advanced communication and high quality graphic displays. The small form factor OEM board offers many unique features that ease the user's learning curve and program development. The board can be used in OEM applications, as well as for education purposes, experiments, and prototype projects. The OEM Board is also perfect for running uClinux with its large on-board RAM and Flash, and network and graphics capabilities.产品特性
- NXP's ARM Cortex-M3 LPC1788 microcontroller in BGA package, with 512kB program FLASH and 96kB SRAM
- External FLASH memories: 128MB NAND FLASH
- External data memory: 32MB SDRAM
- 12MHz crystal for maximum execution speed and standard serial bit rates, including CAN and USB requirements
- 32.768kHz RTC crystal
- 100/10Mbps Ethernet PHY/interface based on SMSC LAN8720
- 256kb I2C E2PROM for storing non-volatile parameters
- Buffered 16- or 32-bit data bus for external expansion
- 200 pos expansion connector (SODIMM-200 format,
- 0.6mm pitch)
- All LPC1788 pins available (except a few used for Ethernet-PHY interface)
- +3.3V only powering
- Onboard reset generation
- Compact SODIMM format: 68 x 55mm
- Six layer PCB design for best EMC performance
产品图片 |
