查看: 400|回复: 0
STM32F407 ARM原型开发板
发表于 2013-7-26 11:21:06 | 显示全部楼层 |阅读模式
Olimex STM32-x407 Cortex-M4单板计算机开发板可以开发由意法半导体制造的Cortex-M4 STM32F407ZGT6单片机应用程序代码。They are low cost entry boards for developing custom applications with the STM32F407ZGT6 MCUs. These boards have plenty of resources and all GPIO ports are available on extension connectors. An Arduino compatible platform connector is also available.The STM32-P407 board also has plenty of RAM, an LCD display, and onboard camera which allows image processing. The Ethernet 100MB interface allows the development of web applications.产品特性
  • 512KB fast external SRAM on board
  • Stereo audio codec CS4344
  • CAN driver
  • Temperature sensor
  • Trimmer potentiometer
  • Joystick for navigation
  • 6610 LCD color 128x128 pixel
  • TFT display
  • SAMSUNG E700 VGA camera 640x480 color
  • Tamper and Wakeup buttons
  • 2 RS232 drivers and connectors
  • 25Mhz quartz crystal
  • 100MB Ethernet
  • Mini SD/MMC card connector
  • Power jack
  • 3V battery connector
  • Extension port connectors for many of the MCU pins
产品图片
GMT+8, 2024-11-26 08:40 , Processed in 0.126097 second(s), 17 queries , MemCache On.
