查看: 214|回复: 0
LatticeECP3 Versa FPGA开发套件
发表于 2013-7-26 14:52:15 | 显示全部楼层 |阅读模式
LatticeECP3 Versa FPGA开发套件在构建各行各业前沿系统上是一个万能的的开发平台。It brings high-end innovations such as configurable SERDES, cascadable DSP slices, and highspeed DDR3 memory within the reach of mainstream designers in an easy to use environment. Customers outgrowing the capabilities of traditional microcontrollers and DSPs will be able to use the Versa kit to develop efficient FPGA solutions to address their emerging high-speed design challenges in applications as varied as Video Transmission and Repeaters, Video Image Signal Processing, Camera Controllers, Network Traffic Management, Resilient Network Construction, and Data Acquisition and Conrol.产品特性
  • Half-length PCI Express form-factor:Allows demonstration of PCI Express x1 interconnection
  • Electrical testing of one full-duplex SERDES channel via SMA connections
  • USB-B connection for UART and device programming
  • Two RJ45 interfaces to 10/100/1000 Ethernet to GMII
  • On-board Boot Flash:64M Serial SPI Flash
  • DDR3-1333 memory components (64Mb/x16)
  • Expansion mezzanine interconnection for prototyping
  • 14-segment alpha-numeric display
  • Switches, LEDs and displays for demo purposes
  • ispVM™ programming support
  • On-board reference clock sources
产品图片
LatticeECP3 Versa评估板用户手册.pdf
2.86 MB, 下载次数: 0
LatticeECP3Versa开发套件简介.pdf
364.2 KB, 下载次数: 0
GMT+8, 2024-11-26 07:34 , Processed in 0.124722 second(s), 18 queries , MemCache On.
