查看: 308|回复: 0
TWR-K70F120M ARM开发套件
发表于 2013-7-25 16:59:24 | 显示全部楼层 |阅读模式
TWR-K70F120M板是一块为K61和K70产品系列而设计的32-bit ARM® Cortex™-M4 MCUs开发板.The TWR-K70F120M operates as a standalone debug tool and can also be combined and used as part of the modular Tower System development platform.产品特性
  • MK70FN1M0VMJ12: K70FN1M in a 256 MAPBGA with 120 MHz operation
  • Touch Tower Plug-in Socket
  • General purpose Tower Plug-in (TWRPI) socket
  • On-board JTAG debug circuit (OSJTAG) with virtual serial port
  • 1Gb of DDR2 SDRAM memory
  • 2Gb of SLC NAND flash memory
  • 3-axis accelerometer (MMA8451Q)
  • Potentiometer
  • Micro-SD Card slot
产品图片产品套件Part Number TWR-K70F120M contains:
  • TWR-K70F120M board with a MK70FN1M0VMJ12 32-bit MCU
  • DVD with software installers and documentation
  • Quick Start Guide document
  • USB Cable
Part Number TWR-K70F120M-KIT also contains:
  • TWR-ELEV – Tower System Elevator Modules
  • TWR-SER – Tower System Serial Module
GMT+8, 2024-11-26 08:21 , Processed in 0.114786 second(s), 17 queries , MemCache On.
