查看: 322|回复: 0
TWR-K60F120M ARM开发套件
发表于 2013-7-25 15:41:36 | 显示全部楼层 |阅读模式
TWR-K60F120M 是一款为Kinetis K10, K20和K60系列产品设计的120/150MHz 32-bit ARM® Cortex™-M4 MCUs开发板. It features the Kinetis MK60FN1M0VMD12 low-power MCU with USB 2.0 HS OTG controller, USB 2.0 FS OTG controller and 10/100 Mbps Ethernet MAC.The TWR-K60F120M operates as a standalone debug tool and can also be combined and used as part of the modular Tower System development platform.产品特性
  • MK60FN1M0VLQ12: K60FN1M in a 144 LQFP with 120 MHz operation
  • S08JM60 based open-source BDM (OSBDM) circuit
  • NAND flash
  • 4 user-controlled status LEDs
  • 4 Capacitive Touch Pads and 2 mechanical push buttons
  • Socket for Capacitive Touch Pad daughter board (Touch TWRPI)
  • Socket for Tower Plugin (TWRPI, e.g. sensor board)
  • Potentiometer
  • Three-axis digital accelerometer (MMA8451Q)
  • SD Card slot
产品图片产品套件Part Number TWR-K60F120M contains:
  • TWR-K60F120M board with a MK60FN1M0VLQ12 32-bit MCU
  • DVD with software installers and documentation
Quick Start Guide document
  • Part Number TWR-K60F120M-KIT also contains:
  • TWR-ELEV – Tower System Elevator Modules
  • TWR-SER – Tower System Serial Module
GMT+8, 2024-11-26 08:42 , Processed in 0.111239 second(s), 17 queries , MemCache On.
