查看: 304|回复: 0
S08/S12评估套件
发表于 2013-7-26 15:02:27 | 显示全部楼层 |阅读模式
DEMOAC为MCUs提供了一个应用平台,其为Flexis连续体的一部分。Target MCUs mount on plug-in modules to support quickly changing the target MCU.The DEMOACEX is a peripheral expansion board designed to interface with the DEMOAC board.The DEMOACEX applies the Freescale MC33794 E-field imaging sensor connected to touchpad in various arrangements.产品特性DEMOAC features:
  • Integrated, USB BDM
  • ON/OFF power switch
  • Power input select option header
       —On-board 5V regulator       —Power from USB BDM       —Optional power sourced to connector J1
  • 4MHz XTAL oscillator
  • 3-axis accelerometer
  • LEDs – four u8ser, one power, one reset
  • Push-button switches – four user, one reset
  • 5K ohm POT
  • Jumpers to disconnect user features
  • 80-pin MCU PORT provides access to MCU signals
  • 4 20-pos pin-headers support plug-in MCU modules
  • IIC termination select header
DEMOACEX features:
  • 80-pin MCU PORT connects to DEMOAC board
  • 9-channel, E-Field sensor
  • E-field touchpad including rotary dial and push-buttons
  • Two low-pass RC filters
  • 5V – 12V boost switcher power supply for E-field sensor
  • LEDs – 10 user, one E-field lamp
  • CAN 2.0 A/B PHY w/ Three-pos header
  • Jumpers to disconnect all IO signals
  • SOIC and TSSOP pads for external IC's
  • Large thru-hole prototyping area w/ +adjacent 5V and GND
产品图片产品套件DEMOAC Board
  • Daughter card for the S08AC128
  • Daughter card for the 51AC256
  • Global Power Adaptors
  • CodeWarrior Development Studio DVD
  • Quick Start Guide
  • User Manual
DEMOACEX Board
  • Quick Start Guide
  • User Manual
飞思卡尔半导体.pdf
4.32 MB, 下载次数: 0
GMT+8, 2024-11-26 07:50 , Processed in 0.137048 second(s), 18 queries , MemCache On.
