查看: 185|回复: 0
LPC1758 ARM评估板
发表于 2013-8-1 17:21:14 | 显示全部楼层 |阅读模式
Keil公司研发的MCB1750评估板,是针对NXP LPC1750系列的ARM Cortex-M3处理器设计的,允许用户对该先进架构创建和测试工作程序。The MCB1750 has a wide range of interfaces making it a great starting point for your next Cortex-M3 project.产品特性
  • 100MHz LPC1758 ARM Cortex™-M3 processor-based MCU in 80-pin LQFP
  • On-Chip Memory: 512KB Flash & 64KB RAM
  • Color QVGA TFT LCD
  • 10/100 Ethernet Port
  • USB 2.0 Full Speed - USB, USB-OTG, & USB Host
  • 2 CAN Interfaces
  • 2 Serial Ports
  • SD/MMC Card Interface
  • 5-position Joystick and push-button
  • Analog Voltage Control for ADC Input
  • Amplifier and Speaker
  • 52 GPIO pins
  • Debug Interface Connectors
        —20 pin JTAG (0.1 inch connector)        —10 pin Cortex debug (0.05 inch connector)        —20-pin Cortex debug + ETM Trace (0.05 inch connector)产品图片
GMT+8, 2024-11-26 07:22 , Processed in 0.105964 second(s), 17 queries , MemCache On.
