查看: 326|回复: 0
CYUSB3KIT-001 USB界面开发工具
发表于 2013-8-7 09:11:09 | 显示全部楼层 |阅读模式
赛普拉斯半导体研发的CYUSB3KIT-001 USB界面开发工具,提供了完整的硬件和软件解决方案,加速EZ-USB® FX3™ 固件和设备驱动程序的开发。It can be used to start hardware or software integration and build final systems after the integration phase is complete. The Cypress Semiconductor EZ-USB® FX3 Development Kit contains the Development Kit PCB, a USB 3.0 A to Micro B cable, the Quick Start Guide, a Kit CD, and a 5V DC adapter.EZ-USB® FX3™ is the next-generation USB 3.0 peripheral controller that enables developers to add USB 3.0 device functionality to any system. FX3 has a fully configurable General Programmable Interface (GPIF™ II), which can interface with virtually any processor, ASIC, image sensor or FPGA. GPIF II provides easy and glueless connectivity to popular industry interfaces such as synchronous Slave FIFO, asynchronous SRAM, asynchronous and synchronous Address Data Multiplexed interface, parallel ATA, etc. The FX3's programming flexibility makes it an ideal solution for any USB 3.0 devices.产品套件
  • Development Kit PCB
  • USB 3.0 A to Micro B cable
  • Quick Start Guide
  • Kit CD
  • 5V DC adapter
产品图片
CYUSB3KIT-001用户手册.pdf
334.65 KB, 下载次数: 0
GMT+8, 2024-11-26 07:35 , Processed in 0.107726 second(s), 18 queries , MemCache On.
