查看: 216|回复: 0
8051 FX2LP 开发套件
发表于 2013-8-8 10:57:49 | 显示全部楼层 |阅读模式
8051 FX2LP 开发套件,一款EZ-USB FX2LP™系列产品,它提供了完整的硬件和软件解决方案,加速了其产品系列固件和设备驱动的开发。The development kits use the actual silicon for the entire development. Cypress's software utilities and example firmware allow the user to generate USB traffic in hours, not weeks!Cypress includes an evaluation version of the 8051 Keil Software Tools in the USB 2.0 development kit. The evaluation version of the C-Compiler lets the designer write 8051 microcontroller applications in C and still get the efficiency and speed of assembly language. Advanced features from Keil tools include the ability to single step through code. This makes it easy to detect errors, handle source level debugging, and set breakpoints. With the ability to debug code one line at a time and to quickly compile and one-step download new code, developers have a more efficient means to complete firmware faster than using emulators. The supplied Keil tools are fully functional, but are limited in object size to 4 kilobytes.产品图片
CY3684产品规格.pdf
55.86 KB, 下载次数: 0
CY3684快速学习.pdf
157.27 KB, 下载次数: 0
CY3684用户手册.pdf
3.87 MB, 下载次数: 0
GMT+8, 2024-11-26 07:43 , Processed in 0.124534 second(s), 18 queries , MemCache On.
