查看: 339|回复: 0
XMC4500 开发套件
发表于 2013-7-31 15:34:13 | 显示全部楼层 |阅读模式
XMC4500 开发套件CPU_45A-V2,集成了XMC4500单片机和三个卫星连接器(HMI,COM,ACT),用于应用程序的扩展。The board along with satellite cards (e.g. HMI_OLED-V1, COM_ETH-V1, AUT_ISO-V1 boards) demonstrates the capabilities of XMC4500. The main use case for this board is to demonstrate the generic features of XMC4500 device including tool chain. The focus is safe operation under evaluation conditions. The board is neither cost nor size optimized and does not serve as a reference design.产品特性
  • XMC4500 (ARM® Cortex™-M4-based) Microcontroller, LQFP-144
  • Connection to XMC4500 satellite cards via satellite connectors COM, HMI and ACT
  • USB OTG Host/Device support via micro USB connector
  • Debug options
       − Cortex Debug connector 10-pin (0.05”)       − Cortex Debug+ETM connector 20-pin (0.05”)       − DriveMonitor2 Stick connector 6pin (0.05”)
  • Reset push button
  • 32MBit quad SPI flash memory
  • Boot from Embedded Flash, UART or CAN
  • Ready for power consumption analysis
  • 5 LEDs :3 Power indicating LEDs、1 GPIO (P3.9) LED、1 RESET LED
  • Potentiometer, connected to analog input P14.1
  • Power supply
       − Via Micro-USB connector in USB device mode       − Via satellite connector pins (COM/ACT satellites cards can supply power to CPU board)       − RTC backup battery产品图片
KIT_XMC45_EE1_001用户手册.pdf
999.82 KB, 下载次数: 1
GMT+8, 2025-1-7 14:25 , Processed in 0.154709 second(s), 18 queries , MemCache On.
