查看: 282|回复: 0
Si7005开发套件
发表于 2013-8-8 15:34:26 | 显示全部楼层 |阅读模式
Si7005开发套件是一款数字式相对湿度和温度传感器。This monolithic CMOS IC integrates temperature and humidity sensor elements, an analog-to-digital converter, signal processing, calibration data, and an I2C host interface. The patented use of industry-standard,low-K polymeric dielectrics for sensing humidity enables the construction of a low-power, monolithic CMOS sensor IC with low drift and hysteresis and excellent long term stability.Both the temperature and humidity sensors are factory-calibrated and the calibration data is stored in the on-chip non-volatile memory. This ensures that the sensors are fully interchangeable, with no recalibration or software changes required. The Si7005 is packaged in a 4x4 mm QFN package and is reflow solderable. The optional factory-installed protective cover offers a lowprofile, convenient means of protecting the sensor during assembly (e.g.,reflow soldering) and throughout the life of the product, excluding liquids(hydrophobic/oleophobic) and particulates.The Si7005 offers an accurate, low-power, factory-calibrated digital solution ideal for measuring temperature, humidity, and dew-point in applications ranging from HVAC/R and asset tracking to industrial and consumer platforms.产品特性
  • Relative Humidity Sensor
       —± 4.5% RH (maximum @ 20–80% RH)
  • Temperature Sensor
       —±0.5ºC accuracy (typical)       —±1ºC accuracy (maximum @ 0 to 70°C)
  • 0 to 100% RH operating range
  • –40 to +85ºC (GM) or 0 to +70ºC operating range (FM)
  • Wide operating voltage range (2.1 to 3.6V)
  • Low Power Consumption
  • 240μA during RH conversion
  • I²C host interface
  • Integrated on-chip heater
  • 4x4mm QFN package
  • Excellent long term stability
  • Factory calibrated
  • Optional factory-installed cover
       —Low-profile       —Protection during reflow       —Excludes liquids and particulates (hydrophobic/oleophobic)产品图片典型应用
  • Industrial HVAC/R
  • Thermostats/humidistats
  • Respiratory therapy
  • White goods
  • Micro-environments/data centers
  • Automotive climate control and de-fogging
  • Asset and goods tracking
Si7005产品规格.pdf
375.5 KB, 下载次数: 0
GMT+8, 2025-1-16 14:04 , Processed in 0.113957 second(s), 18 queries , MemCache On.
