Si5327评估板用于评估Si533xx系列的低抖动时钟缓冲/水平转换器。As shipped from the factory, this evaluation board has the Si53301 device installed. The entire Si533xx family of buffers use the same input circuits and output drivers, and all have the same jitter specifications. Thus, this evaluation board can be used to evaluate any Si533xx device. The Si53301 provides pin-selectable clock output signal format, drive strength control, optional clock division, and per-bank output enable. The Si53304 provides pin-selectable clock output signal format, drive strength control, and individual output enable pins for each clock output.产品特性
- Power supply connections for VDD, VDDOA and VDDOB, GND
- Jumpers for selection of output signal format, output enable, input clock select and output divider
- Jumpers to allow self biasing of CMOS single-ended inputs
- SMA connectors for easy access to test and evaluate the Si53301
产品图片 |
