查看: 298|回复: 0
GSM开发板
发表于 2013-8-15 14:28:53 | 显示全部楼层 |阅读模式
GSM开发板为Silicon Labs Si4133,Si4133G,Si4133G-X2,Si4113G-X5,Si4114G,Si4135,Si4136等器件创建了一个基于PC的评估平台。The board includes all support circuitry necessary to evaluate the synthesizer including a reference clock,SMA connections for external measurement equipment,and an interface to a personal computer for controllingthe device. The PC software is a graphical,easy-to-use interface that allows the user to directly enter frequencies, set divider ratios, and toggle power control options by a parallel port connection. A PC and power supply are all that is needed for a complete evaluation system.产品特性
  • Single board evaluation platform
  • PC-based graphical control software included on CD-ROM for Windows 95/98
  • On-board frequency reference; SMA for external reference
  • SMA connections for synthesizer outputs
  • For use with Silicon Laboratories Si4133, Si4133G, Si4133G-X2, Si4113G-X5, Si4114G, Si4135 and Si4136 synthesizer families (TSSOP or MLP)
产品图片
SI4122M-EVB产品规格.pdf
879.89 KB, 下载次数: 0
GMT+8, 2024-11-26 06:54 , Processed in 0.116323 second(s), 18 queries , MemCache On.
