查看: 269|回复: 0
LCD显示开发套件
发表于 2013-8-15 13:57:55 | 显示全部楼层 |阅读模式
Silicon labs LCD显示开发套件(P/N EZR-LEDK2W-XXX)包含评估Si4455收发器。该工具包有三个版本:一个是434 MHz频段,一个用于868 MHz频段,另一个为915 MHz频段。产品特性
  • The base boards have an LCD display and four LEDs to display information and four push-buttons to receive user commands. Additionally, the Silicon Labs Toolstick Base Adapter is integrated on the board to be easily connected to the PC.
  • The RFpico board provides connection to the Si4455 transceivers. All supported types of RFpico boards can be applied to the base board.
  • The provided software pack contains all the documentation and files needed to develop a user application.
  • The kit supports the use of the Silicon Laboratories Integrated Development Environment (IDE) for software debugging and the use of the Keil & SDCC C compiler, assembler, and linker toolchain.
  • The kit supports use of the Wireless Development Suite (WDS) for setting radio parameters and managing application firmware.
  • The base boards come with the Si4455 range test demo application. The range test demo implements Packet Error Rate (PER) measurement. PER is generally used in wireless systems to measure the quality of the RF link in given circumstances.
产品图片
EZR-LCDK2W-434用户手册.pdf
412.09 KB, 下载次数: 0
GMT+8, 2024-11-26 06:43 , Processed in 0.115787 second(s), 18 queries , MemCache On.
