查看: 326|回复: 0
C8051F020 开发套件
发表于 2013-9-16 09:36:40 | 显示全部楼层 |阅读模式
C8051F020 开发套件包含先进的调试功能,可让用户充分开发和集成的软硬件设计。Since the MCU has built in debug capabilities, it can be installed into the end application. This development system is not encumbered with sockets, target cables or "ICE Chips."A host PC is required to run the development kit software and communicate with the debug adapter. The PC must meet the following system requirements:
  • Windows® 2000 or later
  • One USB port
产品特性
  • Run, halt and single-step
  • Set hardware breakpoints
  • Inspect/Modify memory and registers
  • Download program memory
产品图片产品组件
  • IDE and Product Information CD-ROM, which includes the following:
        —Silicon Labs' 8-bit Microcontroller Software Tools        —Source code examples and register definition files        —Documentation        —Configuration Wizard
  • Third Party Tools and Documentation CD
  • Target/Prototyping PCB (C8051F020TB)
  • Wall mounted universal power supply
  • USB debug adapter
  • USB cable
C8051F02x-DK用户指南.pdf
423.3 KB, 下载次数: 2
GMT+8, 2024-11-26 06:36 , Processed in 0.118277 second(s), 18 queries , MemCache On.
