TMS320F2812 eZdsc入门套件是一个独立的模块,可以让让评价者检查F2812数字信号处理器(DSP)的某些特征,来确定其DSP应用是否满足他们的需求。This module has a single chip parallel port to JTAG scan controller. Therefore the module can be operated without additional development tools such as an emulator. Furthermore, the module is an excellent platform to develop, demonstrate, and run software for the F2812 processor.Host Platform Supported: TMS320F2812Number of Processors: 1Clock Speed Available (MHz): 150 MHzBoard Size: 83 x 146 mm (3.26 x 5.75 inches)External Memory: 1.0Mword Total MemoryExpansion Options: 3 expansion connectorsSoftware Included: Drivers for Code Composer Studio™ IDE产品特性Hardware features:
- TMS320F2812 Digital Signal Processor
- 18K words RAM
- 128K words on chip Flash ROM
- 64K words on board RAM
- Expansion connectors
- Onboard embedded IEEE 1149.1 JTAG controller
- 5 Volt only operation with supplied adapter
- Onboard IEEE 1149.q JTAG emulation
Software Features:
- A copy of Code Composer Studio specifically designed to only work with the eZdsp target
- Compatible with Flash programming utilities from Spectrum Digital
产品图片 |
