查看: 286|回复: 0
TLV320AIC3262评估模块
发表于 2013-8-23 13:42:24 | 显示全部楼层 |阅读模式
TLV320AIC3262评估模块是一个灵活的、高集成度、低功耗、低压立体声音频编解码器模块。The AIC3262 features digital microphone inputs and programmable outputs, PowerTune capabilities, enhanced fully-programmable miniDSP, predefined and parameterizable signal processing blocks,integrated PLL, and flexible audio interfaces. Extensive register-based control of power, input and output channelconfiguration, gains, effects, pin-multiplexing and clocks are included, allowing the device to be precisely targeted to its application.产品特性
  • Stereo Audio DAC with 101dB SNR
  • 2.7mW Stereo 48kHz DAC Playback
  • Stereo Audio ADC with 93dB SNR
  • 5.6mW Stereo 48kHz ADC Record
  • 8-192kHz Playback and Record
  • 30mW DirectPathTM Headphone Driver
  • Eliminates Large Output DC-Blocking Capacitors
  • 128mW Differential Receiver Output Driver
  • Stereo Class-D Speaker Drivers
  • 1.7 W (8Ω , 5.5V, 10% THDN)
  • 1.4 W (8Ω , 5.5V, 1% THDN)
  • Stereo Line Outputs
  • PowerTune - Adjusts Power vs. SNR
  • Extensive Signal Processing Options
  • Eight Single-Ended or 4 Fully-Differential Analog Inputs
  • Stereo Digital and Analog Microphone Inputs
  • Low Power Analog Bypass Mode
  • Asynchronous Sample Rate Conversion
产品图片典型应用
  • Mobile Handsets
  • Tablets/eBooks
  • Portable Navigation Devices (PND)
  • Portable Media Player (PMP)
  • Portable Gaming Systems
  • Portable Computing
  • Acoustic Echo Cancellation (AEC)
  • Active Noise Cancellation (ANC)
  • Speaker Protection
  • Advanced DSP algorithms
TLV320AIC3262产品规格.pdf
921.22 KB, 下载次数: 0
GMT+8, 2025-1-16 14:09 , Processed in 0.130455 second(s), 18 queries , MemCache On.
