查看: 227|回复: 0
ADE7816评估板
发表于 2013-8-27 13:32:35 | 显示全部楼层 |阅读模式
ADE7816评估板包含一个评估板,可以评估ADE7816 6通道能量测量集成电路的性能。The ADE7816 evaluation kit includes evaluation software, written in LabVIEW®, that provides access to the registers of the ADE7816 using a PC interface. This document provides information to assist the user in evaluating the ADE7816.Complete specificationsfor the ADE7816 are available in the ADE7816 data sheet available from Analog Devices, Inc., and should be consulted in conjunctionwith this user guide when using the evaluation board.产品特性
  • Evaluation board to implement a fully functional 6-channel energy meter
  • Accompanying PC-based LabVIEW software
  • Easy connection of external transducers via screw terminals
  • Optically isolated metering components
  • USB-based PC connection
  • External voltage reference option available for on-chip reference evaluation
产品图片
ADE7816评估板产皮规格.pdf
1.64 MB, 下载次数: 0
GMT+8, 2025-1-16 14:03 , Processed in 0.118286 second(s), 18 queries , MemCache On.
