查看: 340|回复: 0
AD5754R评估板
发表于 2013-9-12 09:43:05 | 显示全部楼层 |阅读模式
AD5754R评估板是一个全功能的评估板,用户可以通过它轻松地评估AD5754Rquad-channel,16位DAC的所有特性。All of the AD5754R pins are accessible at on-board connectors for external connection. The board can be controlled by two means, via the on-board connector (J8) or via the USB port of a Windows®-based PC using the AD5754R evaluation software. The default setup is for control via the USB port.产品特性
  • Full-featured evaluation board for the AD5754R
  • On-board reference
  • Link options
  • Direct hook-up to USB port of PC
  • PC software for control
产品图片
EVAL-AD5754REBZ产品规格.pdf
412.13 KB, 下载次数: 0
GMT+8, 2024-11-26 06:24 , Processed in 0.116636 second(s), 18 queries , MemCache On.
