查看: 165|回复: 0
AD9852评估板
发表于 2013-7-22 08:51:57 | 显示全部楼层 |阅读模式
AD9852评估板支持AD9852 DDS设备。When referenced to an accurate clock source, the AD9852 generates a highly stable, frequency, phase and amplitude programmable sine wave output that can be used as an agile L.O. in communications, radar, and many other applications. The AD9852's innovative high-speed DDS core provides a 48-bit frequency tuning word, which results in an output tuning resolution of 1 micro-Hertz, for a 300 MHz internal reference clock input. The AD9852's circuit architecture allows the generation of an output sine wave at up to 150 MHz, which can be digitally tuned at a rate of up to 100 million new frequencies per second. The (externally filtered) sine wave output can be converted to a square wave by the internal comparator for agile clock generator applications. The device provides 14-bits of digitally-controlled phase modulation and single-pin PSK. The on-board 12-bit DDS DAC, coupled with the innovative DDS architecture, provides excellent wideband and narrowband output SFDR. When configured with the onboard comparator, the 12-bit control DAC facilitates pulse-width modulation (PWM) and static duty cycle control, in the highspeed clock generator application. A 12-bit digital multiplier permits programmable amplitude modulation, shaped on-off keying and precise amplitude control of the DDS DAC output.The AD9852's programmable 4x - 20x REFCLK Multiplier circuit generates the 300 MHz (maximum) clock internally from a lower frequency external reference clock. This saves the user the expense and difficulty of implementing a 300 MHz clock source. Direct 300 MHz (maximum) clocking is also accommodated with either single-ended or differential inputs. Single-pin conventional FSK and the enhanced spectral qualities of "ramped" FSK are supported. The AD9852 uses advanced .35 micro CMOS technology to provide this high level of functionality on a single +3.3 V supply.产品特性
  • 300 MHz internal clock rate
  • FSK, BPSK, PSK, chirp, AM operation
  • Dual integrated 12-bit D/A converters
  • Ultrahigh speed comparator, 3 ps rms jitter
  • Excellent dynamic performance :80 dB SFDR at 100 MHz (±1 MHz) AOUT
  • 4× to 20× programmable reference clock multiplier
  • Dual 48-bit programmable frequency registers
  • Dual 14-bit programmable phase offset registers
  • 12-bit programmable amplitude modulation and on/off output shaped keying function
  • Single-pin FSK and BPSK data interfaces
  • PSK capability via I/O interface
  • Linear or nonlinear FM chirp functions with single pin frequency hold function
  • Frequency ramped FSK
  • <25 ps rms total jitter in clock generator mode
  • Automatic bidirectional frequency sweeping
  • Sin(x)/x correction
  • Simplified control interface
       —10 MHz serial 2-wire or 3-wire SPI-compatible       —100 MHz parallel 8-bit programming
  • 3.3 V single supply
  • Multiple power-down functions
  • Single-ended or differential input reference clock
  • Small, 80-lead LQFP or TQFP with exposed pad
典型应用
  • Agile LO frequency synthesis
  • Programmable clock generator
  • FM chirp source for radar and scanning systems
  • Test and measurement equipment
  • Commercial and amateur RF exciter
产品图片
AD9852^PCBZ原理图.pdf
81.65 KB, 下载次数: 0
AD9852^PCBZ产品规格.pdf
1.34 MB, 下载次数: 0
GMT+8, 2024-11-26 08:49 , Processed in 0.127639 second(s), 18 queries , MemCache On.
