查看: 259|回复: 0
AD9640评估板
发表于 2013-7-19 17:43:53 | 显示全部楼层 |阅读模式
AD9640是一个双14位的80/105/125/150 MSPS模数转换器(ADC)。The AD9640 is designed to support communications applications where low cost, small size, and versatility are desired. The dual ADC core features a multistage, differential pipelined architecture with integrated output error correction logic. Each ADC features wide bandwidth differential sample-and-hold analog input amplifiers supporting a variety of user-selectable input ranges. An integrated voltage reference eases design considerations. A duty cycle stabilizer is provided to compensate for variations in the ADC clock duty cycle, allowing the converters to maintain excellent performance.产品特性
  • SNR = 71.8 dBc (72.8 dBFS) to 70 MHz @ 125 MSPS
  • SFDR = 85 dBc to 70 MHz @ 125 MSPS
  • Low power: 750 mW @ 125 MSPS
  • SNR = 71.6 dBc (72.6 dBFS) to 70 MHz @ 150 MSPS
  • SFDR = 84 dBc to 70 MHz @ 150 MSPS
  • Low power: 820 mW @ 150 MSPS
  • 1.8 V analog supply operation
  • 1.8 V to 3.3V CMOS output supply or 1.8 V LVDS output supply
  • Integer 1 to 8 input clock divider
  • IF sampling frequencies to 450 MHz
  • Internal ADC voltage reference
  • Integrated ADC sample-and-hold inputs
  • Flexible analog input range: 1 V p-p to 2 V p-p
  • Differential analog inputs with 650 MHz bandwidth
  • ADC clock duty cycle stabilizer
  • 95 dB channel isolation/crosstalk
  • Serial port control
  • User-configurable, built-in self-test (BIST) capability
  • Energy-saving power-down modes
  • Integrated receive features
       ——Fast detect/threshold bits        ——Composite signal monitor典型应用
  • Communications
  • Diversity radio systems
  • Multimode digital receivers
       ——GSM, EDGE, WCDMA, LTE,        ——CDMA2000, WiMAX, TD-SCDMA
  • I/Q demodulation systems
  • Smart antenna systems
  • General-purpose software radios
  • Broadband data applications
产品图片
AD9640-105EBZ产品规格.pdf
1.2 MB, 下载次数: 0
GMT+8, 2024-11-26 08:45 , Processed in 0.117173 second(s), 18 queries , MemCache On.
