查看: 229|回复: 0
PIC32 GUI开发板
发表于 2013-8-26 17:03:07 | 显示全部楼层 |阅读模式
Microchip Technology公司的PIC32 GUI开发板使用投射式电容触摸技术,使得多点触控的图形用户接口的开发成本变低。This Microchip development board is based on PIC32MX795F512H microcontroller with 105 DMIPS performance, 512KB Flash, and 128KB RAM. The PIC32 is coupled with a low cost PSRAM as a high speed graphics frame buffering and a 4.3” WQVGA touch display, enabling development of graphics solutions without an external graphics controller. Additionally, the board provides USB host and device connectivity and supports I/O connections via through-hole pads for custom board attachment. Multi-touch user input is supported by Microchip MTCH6301 Turnkey Projected Capacitive Touch Controller. The board is a standalone development platform that can be programmed/debugged via the on-board 5-pin In-Circuit Serial Programmer interface designed for Microchip's PICkit3 In-Circuit Debugger.产品特性
  • Based on PIC32MX795F512 device with 512KB Flash and 128KB RAM
  • Projected capacitive touch device MTCH6301
  • WQVGA 4.3” display
  • USB port for Device or Host functionality
  • Expansion header
  • Access to PIC32 I/Os and peripherals
产品图片
PIC32 GUI用户手册.pdf
324.5 KB, 下载次数: 0
GMT+8, 2025-1-16 14:12 , Processed in 0.121523 second(s), 18 queries , MemCache On.
