查看: 406|回复: 0
AT91 ARM7/ARM9仿真器
发表于 2013-7-17 10:01:19 | 显示全部楼层 |阅读模式
SAM-ICE是一个专为Atmel AT91 ARM®设计的JTAG仿真器。它通过USB接口连接到可运行Microsoft Windows 2000,Windows XP和Windows7的PC机。 SAM-ICE内置一个20针JTAG连接器,它由可兼容有ARM®定义的标准20针连接器。产品特性
  • Any Atmel AT91 core supported, including Thumb® mode
  • „ Seamless integration into the IAR®
  • Workbench
  • „ No power supply required, powered through USB
  • „ Maximum JTAG speed 12 MHz
  • „ Auto speed recognition
  • „ All JTAG signals can be monitored
  • „ Support for multiple devices
  • „ Fully plug and play compatible
  • „ Standard 20-pin JTAG connector
  • „ Wide target voltage range: 1.2V to 3.3V
  • „ USB and 20-pin ribbon cable included
  • „ Memory viewer (J-Mem) included
  • „ SAM-ICE TCP/IP server included, can use SAM-ICE via TCP/IP networks
  • „ RDI server available, can use SAM-ICE with RDI compliant software
  • „ Support for adaptive clocking
产品图片
AT91SAM-ICE产品规格.pdf
399.96 KB, 下载次数: 0
GMT+8, 2025-1-16 16:58 , Processed in 0.135453 second(s), 18 queries , MemCache On.
