查看: 281|回复: 0
STM32F407开发板
发表于 2013-7-17 13:56:53 | 显示全部楼层 |阅读模式
STM32F407开发板(STM3240G-EVAL)是一个基于STM32 F4 系列的演示和开发平台,包含一个32位高性能ARM®Cortex™-M4 内核的STM32F407IGH6微控制器。The full range of hardware features on the board is provided to help you evaluate all peripherals (USB OTG HS, USB OTG FS, Ethernet, motor control, CAN, MicroSD card, smartcard, USART, Audio DAC, RS-232, IrDA, SRAM, MEMS, EEPROM… etc.) and develop your own applications.The in-circuit ST-LINK/V2 tool can be easily used for JTAG and SWD interface debugging and programming.产品特性
  • STM32F407IGH6 microcontroller
  • 16 Mbit SRAM
  • 1 Gbyte or more MicroSD card
  • Boot from user Flash, system memory or SRAM
  • Both ISO/IEC 14443 type A and B smartcard support
  • I2C compatible serial interface 64 Kbit EEPROM, MEMS and I/O expander
  • IEEE 802.3-2002 compliant Ethernet connector
  • Two CAN 2.0 A/B channels on the same DB connector
  • RS-232 communication
  • IrDA transceiver
  • USB OTG (HS and FS) with Micro-AB connector
  • Inductor motor control connector
  • I2S Audio DAC, stereo audio jack for headset
  • 3.2" 240x320 TFT color LCD with touch screen
  • 4 color LEDs
  • Camera module and extension connector for ST camera plug-in
  • Joystick with 4-direction control and selector
  • Reset, wakeup, tamper and user button
  • RTC with backup battery
  • Extension connector for daughterboard or wrapping board
  • JTAG, SW and trace debug support
  • Embedded ST-LINK/V2
  • Five 5V power supply options: Power jack, USB FS connector, USB HS connector, ST-LINK/V2 or daughterboard
产品图片
STM3240G-EVAL产品规格.pdf.pdf
180.49 KB, 下载次数: 0
STM3240G-EVAL用户手册.pdf
3.94 MB, 下载次数: 0
STM3240G-EVAL编程手册.pdf
1.67 MB, 下载次数: 0
GMT+8, 2025-1-16 17:01 , Processed in 0.130387 second(s), 18 queries , MemCache On.
