Raisonance’s Primers 对于探测、评估和开发STM32、STM8应用程序来说是独特、轻松且低风险的,包含了用户所需的STM32/STM8外设的实现和操作。The EvoPrimer range is an enhancement of the original Primer1 and Primer2 devices. It offers even more flexibility to evaluate a range of STM32 microcontrollers and STM8L ultralow power line microcontrollers, using the same EvoPrimer base with interchangeable target boards (to test different microcontrollers) or extension boards.The EvoPrimer base has a removable transparent cover and USB cable which includes features such as the debugging/programming interface and most of the hardware features that you need to evaluate the capabilities of the target MCU. The base can also be extended by using its add-on connector to add components and circuitry.The EvoPrimer target board(s) include the target MCU and may also include additional hardware features for target MCU evaluation.The Primers can be purchased as complete evaluation tools, which can then be modified by purchasing an accessory, or they can be created from the interchangeable accessories:The complete evaluation tools for the STM8L and STM32 microcontroller families consist of an EvoPrimer base with the relevant EvoPrimer target board.The EvoPrimer accessories permit the EvoPrimer base and EvoPrimer target boards (and extension boards) to be ordered separately.产品特性
- The versatile EvoPrimer range includes:In-circuit debugging/programming via dedicated USB connection to the host PCEvaluation features including USB connector and MEMs sensorComprehensive development softwareErgonomic designMEMs-based controlsTouchscreen TFT display, color LCDJoystickAudio circuit/JackMEMS accelerometerLi-Ion battery with charge management circuitMicro SD Card™ connectorAdd-on connector for extension boards with USART, SPI, I2C and analog/digital I/Os
- STM8L ultralow power EvoPrimer features:STM8L152C6 MCU with 32 KB FlashLow power consumptionLCD (7-segment)Temperature sensorSolar cells
- STM32F connectivity lineEvoPrimer features:STM32F107VC MCU with 256 KB FlashMini-USB OTG connector
- STM32F performance lineEvoPrimer features:STM32F103VG MCU with 1 MB FlashMini-USB connector
- STM32F high-performance and Digital Signal Processing (DSP) EvoPrimer features:STM32F407IG MCU with 1 MB Flash1.3 M pixel image sensor3-axis gyroscope16 Mbit of SRAMSTA529A audio-codecMini-USB connector (HS, USB 2.0 OTG) and dual CAN connector
- STM32L ultralow power EvoPrimer features:STM32L152VB MCU with128 KB FlashLCD (14-segment)Temperature and pressure sensorsSolar cells and Li-ion battery
- Inertial sensor extension board features:3-axis gyroscopePressure and temperature sensorMagnetometer and accelerometer
- Primer2 (STM3210E-PRIMER) and Primer1 (STM3210B-PRIMER) are replaced by the STM32F performance line EvoPrimer.
