查看: 321|回复: 0
电池监视演示板
发表于 2013-7-17 13:35:43 | 显示全部楼层 |阅读模式
STEVAL-ISB012V1演示板基于具有高效气体压力表的STC3105,实现监测单锂子电池的电压、电流和容量。The STEVAL-ISB012V1 demonstration board has an internal charger in order to charge the battery and can be powered through a USB port or by using a DC adaptor.产品特性
  • The STC3105 device uses the Coulomb counter method to track state-of-charge (SOC) or to track when the battery is charging or discharging
  • Accurate measurements of the battery voltage to estimate the battery state-of-charge
  • Battery parameters are sent to the PC via USB using a virtual COM port and can be observed using HyperTerminal as well as a GUI
  • The board can also display parameters on the LCD
  • Charging and discharging status is displayed by the + and - sign respectively on both the LCD and LED
  • The board also shows low voltage and SOC alarms
  • The board can monitor a battery with a capacity up to +/-10950 mAh
  • RoHS compliant
产品图片
SBC2416G评估套件概述.pdf
1.02 MB, 下载次数: 0
DM240013-2用户指南.pdf
2.44 MB, 下载次数: 0
GMT+8, 2025-1-16 16:45 , Processed in 0.115902 second(s), 18 queries , MemCache On.
