查看: 481|回复: 0
Parallax 图像传感器开发板
发表于 2016-5-13 09:05:25 | 显示全部楼层 |阅读模式
TSL1401-DB是一个子卡,它提供了一个TAOS TSL1401R128像素线阵传感器和一个透镜。模块将允许它的主机系统“观察到”在一维。二维视觉可通过移动测试者或移动垂直于传感器轴的方向上的传感器来实现的。Parallax TSL1401线扫描成像子板提供一维的景象给所有的微控制器。它是专为具有视差的BS2pe主板插件进行兼容,但可以与其他 BASIC Stamp modules,  Parallax Propeller, SX, PICs, 和AVRs一起使用, 以仅举几例。它不仅适用于评估 TAOS's TSL1401R成像芯片,而且也供纳入OEM产品,以及业余爱好者,机器人,以及教育平台的平台。Features
  •  Provides vision in one dimension with 128-pixel resolution.
  •  Three-line serial interface with analog intensity output for each pixel.
  •  Included 7.9mm lens provides a field of view equal to subject distance.
  •  Plug-compatible with Parallax motherboards.
  •  Coprocessor driver firmware for the MoBoStamp-pe available for download.
  •  Can be interfaced directly to a BASIC Stamp for some functions.
  •  Onboard accessory socket for strobe output or 50/60Hz fluorescent light sync input.
  •  Runs from 3.3V or 5V supplies. (5V is needed for the optional LED strobe attachment.)
Applications
  •  Measure height, width, diameter, thickness.
  •  Locate objects, lines, edges, gaps, holes.
  •  Count items; measure conveyor coverage.
  •  Determine volume, shape, orientation.
  •  Read simple barcodes.
  •  Learn the principles of machine vision.
TSL1401-DB Product Overview.pdf
893.77 KB, 下载次数: 1
GMT+8, 2024-11-24 20:34 , Processed in 0.136704 second(s), 16 queries , MemCache On.
