查看: 347|回复: 0
OMAP5432单片机评估板
发表于 2016-4-12 09:16:33 | 显示全部楼层 |阅读模式
OMAP5432 EVM 建立在双通道 1.5GHz ARM® Cortex™-A15 MPCore™ 基础之上,其性能可使应用以前所未有的速度运行。该产品是一款高成本效益工具,不但可进行软件原型设计、评估应用,而且还可针对设计进行基准测试。该 EVM 可帮助客户便捷访问以太网、USB 3.0、USB 2.0、HDMI、音频 I/O 与 SATA 等重要接口以及可提供多种显示及摄像机选项的扩展端口。该产品提供电源管理与热管理框架,可在各种应用中实现无风扇工作。此外,该工具还配备了定制型配套电源管理集成电路 (PMIC)——TWL6040 音频编解码器。OMAP5432 EVM 可帮助客户在能为工业应用提供所需处理功能的器件(具有 OMAP™ 平台和处理能力所需的多媒体及图形功能)上快速评估应用。TI 基于 OMAP 5 架构的模块产业环境和设计合作伙伴可帮助工业客户快速从评估转向生产,帮助他们降低开发成本,加速产品上市进程。”Features
ProcessorOMAP5432 ES2.0
Onboard DDR3L2GB
Non-volative Memory4GB EMMC/iNAND Ultra device
PMICTI
Debug Support14-pin JTAG, GPIO Pins UART via micro-USB connector, LEDs
PCB5.0" x 3.97" (127.00mm x 100.84 mm), 10 layers (8 Routing)
Indicators2 blue LEDs (GPIO-controlled), 5 green LEDs (I2C-controlled), one tri-color RGB LED (I2C-controlled), Green Debug Power LED, Red Power Input Voltage Indicator
HS USB 3.0 OTG PortUSB3.0 connector, supports optional plug-in of micro-USB connecto
HS USB Host PortThree USB HS Ports, two to onboard connector, one provided via 0.1" pitch header
Audio Connectors3.5mm, Stereo out, 3.5mm, Stereo In Headset Jack (earphone/microphone)
SDIO Connector4-bit Micro-SD card cage, push/push
VideoHDMI via native OMAP HDMI interface, DSI Display Expansion (DSIPORTA and DSIPORTC), Parallel Display Expansion (DPI) via 100-pin expansion connector
Power ConnectorDC Power
CameraSingle MIPI CSI-2 camera and/or parallel camera/dual MIPI CSI-2 sensors supported via camera expansion connectors
Expansion Connector(s)See Generic, Main, Camera, and GPMC Expansion sections of this document
OMAP5432 EVM Quick Start Guide.pdf
315.83 KB, 下载次数: 0
GMT+8, 2025-1-13 07:56 , Processed in 0.112567 second(s), 16 queries , MemCache On.
