查看: 271|回复: 0
MSP430F5510 MCU开发板
发表于 2016-4-13 10:29:17 | 显示全部楼层 |阅读模式
OLIMEXINO-5510开发板可实现对由德州仪器生产MSP430F5510的微控制器进行运行的应用程序代码开发。OLIMEXINO-5510 is intended to work with Energia - an Arduino-like IDE for MSP430. The community is working on adding full support for Energia. At the time of writing this manual such support isn't fully added but it is on the way. When such support is implemented there will be software examples below in Energia format.OLIMEXINO-5510 was specially designed for the EasyMSP project which is created by Matthew Burmeister (a.k.a. MattTheGeek from 43oh.com). Matt did amazing work by creating Arduino-like language and commands to compile with MSP430 hardware just adding these in header files, so they compile with MSPGCC. However, personal problems restrained Matthew to finish the project he started. That is why Energia is the now default and recommended development environment.The target market are the MSP430 fans and electronics beginners. People with better understanding of software than hardware. Arduino platform fans. Feature
  • MCU: MSP430F5510 with 32K Bytes Program Flash, 4K Bytes RAM, 25Mhz 
  • Power supply circuit 
  • Power-on led 
  • Li-Po battery connector
  • Li-Po battery recharge circuit
  • RTC (Real-time clock) quartz crystal
  • UEXT connector
  • User LED
  • SBW interface 
  • User button, boot button and RESET button
  • Reset button 
  • FR-4, 1.5 mm, soldermask, component print
  • Dimensions: 53.3mm x 55.9mm (2.1'' x 2.2")
OLIMEXINO-5510 user's manual.pdf
1.35 MB, 下载次数: 0
GMT+8, 2025-1-13 07:45 , Processed in 0.116765 second(s), 17 queries , MemCache On.
