查看: 187|回复: 0
AT91SAM9G25评估套件
  • 签到天数: 11 天
    发表于 2013-5-22 10:47:47 | 显示全部楼层 |阅读模式
    AT91SAM9G25评估套件适用于评估AT91SAM9G25的开发设计应用。
    特性
    • 400MHz CPU
    • External memory
    • DDR2-SDRAM (1Gb)
    • NAND Flash (2 or 4Gb)
    • Three USB ports
    • HS (EHCI) and FS (OHCI) Host, multiplexed with HS USB Device via Micro AB connector
    • HS (EHCI) and FS (OHCI) Host, via standard type A connector
    • FS only (OHCI) Host, via standard type A connector
    • Two Ethernet 10/100 interfaces with on-board MAC controllers and RJ45 sockets
    • Two high-speed SD/MMC interfaces
    • One ISI interface
    • One stereo CODEC interface with line-in and headphone jacks
    • One telephone/modem interface with RJ11 connector
    • Three serial interfaces (2x USART, 1x UART)
    • One Two-wire Interface (TWI)
    • One Zigbee® extension port
    AT91SAM9G25评估套件用户指南.pdf
    6.38 MB, 下载次数: 0
    GMT+8, 2025-1-16 17:04 , Processed in 0.116227 second(s), 16 queries , MemCache On.
