查看: 241|回复: 0
SAM3S-EK2评估套件
  • 签到天数: 11 天
    发表于 2013-5-20 14:43:10 | 显示全部楼层 |阅读模式
    SAM3S-EK2评估套件可快速地开发评估Atmel SAM3S微控制器的开发应用。
    关键特性
    • SAM3SD8 LQFP100 chip with optional socket footprint
    • 12 MHz crystal
    • 32.768 KHz crystal
    • Optional SMB connector for external system clock input
    • NAND Flash
    • 2.8 inch TFT color LCD display with touch panel and backlight
    • UART port with level shifter circuit
    • USART port with level shifter circuit multiplexed with RS485 port with level shifter circuit
    • Microphone input and mono/stereo headphone jack output
    • SD/MMC interface
    • Reset button: NRST
    • User buttons: Left and Right
    • QTouch® buttons: Up, Down, Left, Right, Valid and Slider
    • Full Speed USB device port
    • JTAG/ICE port
    • On-board power regulation
    • Two user LEDs
    • Power LED
    • BNC connector for ADC input
    • BNC connector for DAC output
    • User potentiometer connected to the ADC input
    • ZigBEE connector
    • 2x32 bit PIO connection interfaces (PIOA, PIOC) and 1x16 bit PIO connection interface (PIOB)
    ATSAM3S-EK2用户指南.pdf
    938.65 KB, 下载次数: 0
    GMT+8, 2025-1-16 17:09 , Processed in 0.119233 second(s), 16 queries , MemCache On.
