查看: 224|回复: 0
ILD6150 LED驱动器评估板
发表于 2016-4-18 09:31:44 | 显示全部楼层 |阅读模式
Infineon公司的ILD6150是60V/1.5A高效降压LED驱动器,电源电压从4.5V到60V,开关频率高达1MHz,软起动功能,模拟和PWM调光,输出电流精度3%,LED电流温度漂移很低,效率高达98%,主要用在通用照明的LED驱动器,街道和隧道照明以及办公室和住宅区照明。Features
  •   Wide input voltage range from 4.5 V to 60 V
  •   Capable to provide up to 1.5 A average output current
  •   Up to 1 MHz switching frequency
  •   Soft-start capability
  •  Analog and PWM dimming possible
  •   Integrated PWM generator for analog dimming input
  •   Typical 3% output current accuracy
  •   Very low LED current drift over temperature
  •   Adjustable over-temperature protection
  •  Undervoltage lockout
  •   Over-current protection
  •  Thermally optimized package: PG-DSO-8-27
ILD6150 Datasheet.pdf
1.33 MB, 下载次数: 0
GMT+8, 2025-1-13 07:55 , Processed in 0.120309 second(s), 17 queries , MemCache On.
