查看: 259|回复: 0
M24LR-DISCOVERY
  • 签到天数: 11 天
    发表于 2013-5-14 14:24:35 | 显示全部楼层 |阅读模式
    M24LR-DISCOVERY是一个验证M24LR04E-R双接口EEPROM 芯片性能的即时可用的开发套件,它被广泛应用于工业设备、医疗设备和消费电子。Key Features
    • M24LR boardM24LR04E-RMN6T/2 Dual Interface EEPROM with I2C and ISO/IEC 15693 RF interfaces, 4 Kbits of EEPROM and password protection in SO8N packageSTM8L152C6T6 8-bit microcontroller, with 8 Kbytes of Flash memorySTTS751-0WB3F, low-voltage digital temperature sensor20 x 40 mm inductive antenna etched on the PCBTwo function buttons (User and Reset)SWIM connector for programming and debuggingI2C connectorsLCD (24 segments, 4 commons)
    • RF transceiver boardCR95HF-VMD5T 13.56 MHz multi-protocol contactless transceiver IC with SPI and UART serial accessSTM32F103CB 32-bit microcontroller, with 128 Kbytes of Flash memory47 x 34 mm 13.56 MHz inductive antenna etched on PCB and associated circuitryUSB connector for communication with host PC and demonstration board powering
    M24LR-DISCOVERY简介.pdf
    259.15 KB, 下载次数: 2
    M24LR-DISCOVERY用户指南.pdf
    739.71 KB, 下载次数: 2
    M24LR-DISCOVERY BOM.pdf
    33.34 KB, 下载次数: 2
    M24LR-DISCOVERY电路原理图.pdf
    101.51 KB, 下载次数: 3
    GMT+8, 2025-1-16 16:57 , Processed in 0.107248 second(s), 16 queries , MemCache On.
