查看: 284|回复: 0
S6E1A1 MCU开发套件
发表于 2016-4-21 14:16:48 | 显示全部楼层 |阅读模式
Cypress公司的S6E1A1系列是高度集成32位MCU,采用ARM Cortex-M0+处理器,集成了多达88kB片上闪存和SRAM,以及如各种计时器,ADC,通信接口(UART, CSIO, I2C, LIN)等外设功能,CPU工作频率40MHz,主要用在低功耗和低成本的应用。Features:
  • Power Supply: 2.7 to 5.5V
  • Up to 40MHz frequency
  • Up to 88Kbytes flash and 6Kbytes SRAM
  • Up to 3 channels of Multi-Function-Serial (MFS) interface with 128bytes FIFO
  • One 12-bit A/D Converter; Max. 8 channels
  • One Real Time Clock
  • DMA-Controller (2ch)
  • One Multi-Function-Timer (MFT) and Quadrature Position/Revolution Counter (QPRC), e.g. Motor control
  • Timers (base timer, dual timer, watch dog, etc.)
  • Low Voltage Detection and Clock Supervisor module
  • 32/48 LQFP and QFN, 52 LQFP
SK-FM0-V48-S6E1A1 Quick Start Guide.pdf
1.46 MB, 下载次数: 1
GMT+8, 2025-1-13 07:35 , Processed in 0.124717 second(s), 17 queries , MemCache On.
