查看: 275|回复: 0
PIC18F4550 单片机开发板
发表于 2016-4-21 15:40:54 | 显示全部楼层 |阅读模式
PIC-USB-STK是入门套件可以让你去探索PIC18F4550和Microchip USB固件的所有功能。PIC18F4550该器件系列具备所有PIC18 单片机固有的优点,即以实惠的价格提供出色的计算性能,以及高耐久性的增强型闪存程序存储器。除了这些优点之外, PIC18F4550 系列还增强了器件设计,使得该系列单片机成为许多高性能、低功耗应用的明智选择。Feature:
  •  CPU: PIC18F4550-I/P on DIL socket
  •  ICSP/ICD connector for programming with PIC-ICD2
  •  USB 2.0 type B connector allow board to be interfaced to PC host.
  •  RS232 connector
  •  SD-MMC connector
  •  Audio In, Audio Out connectors
  •  Status LEDs
  •  Trimmer potentiometer POT
  •  Four buttons
  •  Quartz crystal 20Mhz
  •  Reset button
  •  Power plug-in jack with diode bridge can be powered with AC or DC power supply
  •  5V voltage regulator
  •  Extension slot for the not connected ports
  •  Four mounting holes 3,3 mm (0,13")
  •  FR-4, 1.5 mm (0,062"), green soldermask, white silkscreen component print
  •  Dimensions 104x76 mm (4,1x3")
GMT+8, 2025-1-13 07:48 , Processed in 0.112552 second(s), 15 queries , MemCache On.
